Play in Auto gear stick lever?
sat.panesar@banctec.co.uk
New Registration
Hopefully someone could be kind to help me with a small question.
I have a 1998 W210 E280 (auto). Lately, the gear stick seems to have a bit of play in it. The gears select fine but the lever itself has play in it. By this I mean.... when R is selected, the lever moves freely about a centimetre each way (up and down). Also when I move the gear stick to D, I hear a noise as if something is loose inside the gear stick panel. Something like a bolt maybe.
Could anyone tell me what this may be and if I can fix this myself?
Help would be much appreciated.
Thanks,
Sat.
if I put a drawng up you would never read it. Normally with these shifts you have two sides. the side near the driver is the safty interlock. the other side normally operates a cable to the box. You have to take out the center console to access it. Once you can see it you will find what needs to be tightened up. Do not alter the lengths of any cables
Malcolm
Bluegrass
W210 E320 Avantgarde 2000
I've just had the same thing happen to my W210 320CDI.
Television by any chance would you be kind enough to post a picture or diagram to help with this repair?
I've removed the centre console exposing a black housing from where the gear stick comes out. At this stage I can't see anything loose.
Also how do I remove the gear stick knob?
Thanks.
If you would care to PM me and mark it 210 gear shift and give me your email address I will see what I have
I have sent the 210 shift papers, I hope that it will help
Bluegrass
Thanks Malcolm,
I'll have a go.
Do you know how to take of the gear knob?
Turn the collar underneath ½ turn and it lifts off I think
wireman
lancashire
It probably isn't but if its anything like older 124/201 models with a mechanical levers and rod arrangement there are plasic bushes at the lower end (beneath the car) of the gear lever and in the selector lever on the box. They cost about 50p each but are a rather difficult part to access and press/clip in the replacement, you can see them but they are in such a tight place its almost a gearbox out job to fit new ones, at least the cross member needs to be lowered.
I left the job undone on my 201.
amalikha
W210 gear stick lever play
Hi Television,
My 210 e240 gear lever stick play..heard something loose when i shift the lever. Could you please send the drawing (if you still have it) so i can direct the problem to my mechanic. Try to PM you but seems that your mailbox is full. Thanks in advance. Cheers
kamalpatel12448
North West London
C63 W204 (2008) and C240 W202 (1999)
I had something similar happen to my W202 it turned out to be a bush and was changed fron the underside if I'm not mistaken.
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
There is a tiny bush in the selector road that breaks apart, 202's are quite common for it too. About £10 for the parts and no more than an hours work for any garage worth their salt!
Tel: 020 8863 9233
