Arzaam
- Oct 13, 2014
- Age
- 27
- Location
- Pakistan
- W203 2002 c180
i got to know from the previous owner of my car whom i am still in touch that the steering rack was changed of this car as it was leaking previously and for now it has ATF instead of Central Hydraulic fluid in it to check for leaks etc, the same Mercedes Benz gear oil that goes in transmission
car has only been driven 1000km since then, i should change it to the correct central hydraulic fluid is there any harm running like this? steering feels as it should too and no noise either,
whats the way to change it is it length? it has a drain nut at the bottom and undershield has to be removed? what about bleeding? it takes 0.75 litre of fluid?
