Thanks for the reply, I suppose you couldn't tell me where the oil filter is - 190E 1990 2.0 ....... surely I don't need to remove the air filter housing to get at it - else I can't find it.
The oil filter is mounted vertically at the back of the engine and you have to remove the air filter housing to get at it. Your car should have a cartrige type filter, earlier models had a replacement element.
On this topic, can anyone tell me how often the power steering fluid and filter needs changing, since my Haynes seems to miss this out altogether (other than to tell me to only use Merc fluid, as in the item above)
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
