Thanks for the reply, I suppose you couldn't tell me where the oil filter is - 190E 1990 2.0 ....... surely I don't need to remove the air filter housing to get at it - else I can't find it.
The oil filter is mounted vertically at the back of the engine and you have to remove the air filter housing to get at it. Your car should have a cartrige type filter, earlier models had a replacement element.
On this topic, can anyone tell me how often the power steering fluid and filter needs changing, since my Haynes seems to miss this out altogether (other than to tell me to only use Merc fluid, as in the item above)
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
