Powerfold Lubrication ?
Taihape
Edinburgh
2005 E320cdi avantgarde est AMG 18's command plus lots more
My mirrors are starting to get a bit "scrunchy" on opening /closing, do I just blast a few squirts of WD40 in the general direction of the hinge or is there a more targeted approach to this fix ?
Many thanks
Taihape
whitenemesis
CLS55 AMG '05
I use PTFE dry lube (designed for mountain bike chains!) as it doesn't attract dirt and is very, erm, slippy :)
The noise usually comes from the rubber seal at the hinge to the rear side. A little squirt along the egde works wonders!
Try and squirt some into the fulcrum point, PTFE that is
Miffy
Bromley, London
CLK 320 CAB Elegance C208
perhaps there should be a government health warning on WD40 to say its a release/penetrating oil and has no lasting lubrication properties.
Indeed there should be, it is a release agent as you say, and dries when used as a lubricant, I am surprised that it never gets used to fix the "er indoors" syndrome
