Pressure sensor W221 2006 's' class 320
LPGJOE
Tavistock
06 320 S class CDi
Hi guys , got a fault showing on code reader indicating a fault with the pressure sensor on the air suspension, 1. is it an easy thing to replace ? 2. Where do i find it ?
Thanks for any help.
Cole@MBS
www.mbssouthampton.co.uk
Need more info ?? Guessing it’s the pressure relief valve on the side of the compressor , what’s the car doing???
LPGJOE
LPGJOE
Tavistock
06 320 S class CDi
Just comes up sometimes on dash showing the sign of suspension fault riding ok replacement compressor & valve block changed 4 mths ago, plug in icarsoft unit comes up pressure sensor, have cleared fault and waiting for fault to show again, if and when it does i will give more information, could be old fault still left on system, Thanks for your prompt reply.
LPGJOE
LPGJOE
Tavistock
06 320 S class CDi
Just plugged in icarsoft unit has suspension fault came up again, its telling me (Recovery time during filling central reservoir is to long) would this be the pressure sensor ?
Cole@MBS
That sounds like the compressor has either a leak or is getting worn out!! Can you do a fill time test on that bit of kit??
LPGJOE
LPGJOE
Tavistock
06 320 S class CDi
I will run it down to a local MB independent guy , he has a 'Star' reader, new pump was fitted in june ! maybe faulty unit.
