normanj
Hello,
I have a problem with transmission. When I go forward, the car is OK. If I use the reverse then forward, the car gets stuck in low gear, constantly. To overcome this, I have to stop and turn the engine off for a few minutes. I turn the engine on and go forward, and the gears then change fine.
Do I have to change the oil for transmission?
As the car has done 72000 miles.
Or is the problem that the whole gearbox needs changing?
Also to note, I've had a diagnostic test:
P0100 hotfilm mass airflow sensor B39.
P1403 exhaust gas recirculation HFM - SFI controlled
Thank you
Thank you
