Proud new SL 65 Owner!
On a 54 plate then you have the Comand APS and not the 2, so you will have the MOST as well. The eject mechanism is very different as well, I would imagine that a child may have popped something in the slot
M
Mr_Rouse
Westcliff-on-Sea
SL 65 AMG
  • #22
Hi Malcolm
Sorry what is MOST? I think you might be right.. I might see if I can find one of these ebay firms you mentioned
Paul
drmw
Yorkshire
www.autonomed.co.uk
The phone cradle is under the arm rest and nothing is visible other than the cradle itself..
All you need in that case is Viseeo bluetooth unit (search this forumfor many details) - sits in the cradle, talks to your phone but fools the car into thinking there's an actual phone in the cradle. I have the same - works perfectly
Hi Malcolm
Paul
The D2b and the MOST are high speed data system, the early D2b could only handle 5-6 things at the best and not very fast, the MOST can handle much more information and up to 20 items at a high speed
On Ebay it comes under audio and navigation, you could return the unit to Becker in Wales
M
Mr_Rouse
Westcliff-on-Sea
SL 65 AMG
  • #25
I might check out this C A T Audio lot in Brentwood given I am in Essex and see what they can do...
