David Arnott
jaybtee,
The WIS document no. is ar88.50-p-5020r
When you operate the handle in the boot lid this makes the PSE pump blow pressure to the lock mechanism, the pneumatic solenoid then directs this pressure to the black diaphragm part which unlocks the boot.
The white diaphragm part is supplied from the PSE with vacuum when you close the boot lid on to the first click of the lock, the boot lid then is pulled down and locked with a further click.
The pressure and vacuum are applied on the same yellow plastic line and is then directed to the appropriate diaphragm by the solenoid. The PSE can make both pressure and vacuum.
The electrical wiring diagram / schematic is pe80.20-p-2101-97ka in WIS
I hope this helps, don’t hesitate to ask more questions
Regards
David
Regards
David
