Puncture: can't get my wheel off
Others above have done similar ...... I don't suppose knocking seven bells out of an alloy with a big hammer (& block of wood) is going to do it any favours either :rolleyes:
I can see someone hitting the tyre hard and the hammer bouncing back into them...my dad broke his skull in a similar way with an axe...
EmilysDad
Bury Lancs
ML350
yep ;)
just googled it and found this pic which is almost exactly the same as the little packet I've got.
Richard Elliot
Lisbon, Portugal
1999 E270CDi
I had this problem two days ago... banged the rim of the wheel with the end of a heavy bit of wood in various places and off it came. I don't see how the car could possibly fall off the jack doing this, its all lateral force.
If I had been stuck in the rain and dark on a busy road though ...nasty!
Levering can bring it off the jack not banging it ;)
Rockall
Donegal Ireland
Many
When you do get it off, I suggest that you then check all the rest of the wheels and also smear some grease on the inside mating surface - where the alloy wheel actually touches the wheel hub.
Better to do this now in your driveway rather than at night, miles from home, it is raining and the torch doesn't work!!
Regards
Bill
Frontstep
T210 320cdi
Clean the corrosion off then copper grease.
tode
NW FRANCE
S350 btec 2011
I've always found that if something won't move on a Mercedes, then kicking it does the trick. :rolleyes:
Querido
Querido
London
2nd Generation A Class
  • #30
all fixed .... my local mechanic's been out, gave it a good kicking, took the wheel to a nearby tyre shop, got it fixed & balanced, put it back on .... £40!
tode
NW FRANCE
S350 btec 2011
Ther you are, that's the way to do it :D :D
Rockall
Donegal Ireland
Many
Now save yourself £120 and go and check the other three!!
Regards
Bill
www.W140.co.uk&www.r129.co
