question Diesel or Petrol
Royston59
Surrey
2014 CLS 350 CDI AMG Sport & 2014 C220 CDI AMG Sport edition (Wifeys)
I know its been done to death but its always a facinating topic for the answers it throws up........
Do Diesel engines out last Petrol engines and (if so) why?
We are not talking specifics here eg machinery in a commercial sense, simply Cars in general...
Cheers
R
R
Royston59
Surrey
Mileage or years?
ah now there's a thought....I guess it must be mileage as I have seen a lot of engines out last the car that surrounds them...:D
Cheers
peterwhayward
grays essex
E240 classic est 2000 2.4
without a real study done by any body of people its a difficult question to answer. i would think that most peoples perception is that diesels do last longer, but.......................that would only be the case if both cars were driven in the manner that they were intended with equal care given to both in terms of servicing etc. In real terms if the above was the case I would think that the diesel would do more miles if used for sustained distances (as intended), but last longer?, i'm not so sure.
I am sure there is no difference in the 2 mileage wise, there is no reason for them to be any different from each other, technically the petrols should win as the diesels run with a higher compression
But diesels don't rev as high therefore less wear will occur, particularly when cruising.
Debatable as thrust can cause more wear and my CL500 cruises at 70 at just under 2k rpm
S80
North Lincolnshire
None at the monent, but there's an OM642 in the Jeep Grand Cherokee!
Just a quick search on autotrader.co.uk for cars over 10 years old reveals:
3854 diesel
21873 petrol
GeeAy
Notts
2016 W205 C220 SE Exec
I'm not a an automotive engineer, but my feeling is there are a number of areas which lead to an Oil burner being more robust. Firstly the componants are built like brick outhouses to contain the pressure required to combust and the pressure generated as BMEP (Break Mean Effiective Pressure which relates to the motive force generated). Secondly the high BMEP means the engine runs at significantly lower revs thus reciprocating wear over time is reduced. or something like that. But lower revs and stronger components probably covers it.
peterwhayward
grays essex
3854 diesel
21873 petrol
Thats because nobody sells a diesel thats just been run in.....where as petrol, they all want to get rid of.;)
Silver_Star
Rural Leicestershire near where Pork Pies and Stil
W203.006, S211.208 Land Rover 90
Diesel is an oil, where as petrol is a solvent, which must have an effect on longevity. Diesel also has a lower combustion temperature.
In reality in modern cars, the engine will still be ticking when the rest of the car is ready for the scrappy.
S80
North Lincolnshire
Or alternatively because the high cost of diesel ancillary failures is enough to write off an older car?
GeeAy
Notts
Or they rattle so badly from new that you dont realise they've been knackered for the last 100k so keep driving it..
Let's not forget diesel wasn't as common 10+ years ago. They didn't used to put the power out they do now in comparison.
And at what cost, port motors, flaps, DPF's pumps, injectors, compressors, they are not like the old simple 603 engines, they can cost a lot of money to keep them going
And the horrible smell to go with the noise ;):D
Sue new MB owner!!
Manchester UK
SLK 200 /2009 /1.8
I think Diesels sound like Taxi's .... nowt wrong with Taxi's ... but...
Petrol engines just.... welll... sound better!!! ..... sorry no tech blah blah from me!! :D
