R107 MOT comments
mcilwain
SL 500
Hi, I’m looking at a 1986 R107 registered on 1/3/86. A couple of questions
1 - would this be the last variant of the R107 (1986-1989)
2 - the following comments were noted on the last MOT, should I buy and what would be the approx cost to get fixed by a specialist?
Thanks for viewing
Regards
Nearside Front Lower Suspension arm ball joint has slight play (5.3.4 (a) (i))
Advice
Offside Front Lower Suspension arm ball joint has slight play (5.3.4 (a) (i))
Minor
Nearside Front Lower Suspension arm ball joint dust cover severely deteriorated (5.3.4 (b) (i))
Minor
Offside Front Lower Suspension arm ball joint dust cover severely deteriorated (5.3.4 (b) (i))
Advice
Steering box has slight free play detected at steering wheel (2.3 (a) (i))
Advice
Offside Rear Inner Vehicle structure is corroded but structural rigidity is not significantly reduced wheel arch (6.1.1 (c) (i))
Hello and welcome
Wearsafoxhat
Sunny Hampshire by the sea
Hi and welcome,
No idea of costs but that list doesn’t look too bad.
I think the problem may be in sourcing the parts needed.
Meat and drink jobs for a decent indy.
Steering rack could be expensive - if thats the cause of play.
The rust issue would need new metal - Good body shops can get repair panels.
If your CV are shot beyond the covers - then you may well need new shafts.
If I was you, get yourself to an indy and ask for a price. Some things of course he cant quote out seeing the car!
00slk
Cambridgeshire UK
Hello and welcome
The fun is in buying and then repairing ;)
A.J.
Norwich. UK
Hi and welcome to the forum :)
mcilwain
SL 500
Thanks, everyone. Any ideas if this is the last variant of the R107 based on the registration date and in addition what would should I do in terms of servicing etc should I purchase it? PS as you may have guessed im fairly new to the older car purchasing so go easy
Only you can decide if you should purchase it given its condition, your ability, what support you have from nearby garages.
The biggest issues with cars of that age are rust (really important to keep on top of it) and parts availability (and because of scarcity parts prices).
Basic servicing is easy. Oil, filters, spark plugs is all you need of most of the time.
mcilwain
SL 500
Thanks for the info
Pffttg how long is a piece of string.
Many factors, your budget, how much cost to get the car how you like and fixed, part availability (gen MB or cheap - your call), have you a good merc indy nearby,
if its your dream car, and you have the cash - go for it, you only live once!
