R107 starter removal
tomadaly
cork, ireland
450SL - 1973 - auto
HELP :confused: I have a 1973 450sl auto - and the stater is dead - trying to remove ot to get it reconditioned. From under the car I have reomved a 19mm bolt on the starter - but I assume there is another bolt - I can't see one or even feel where it moght be. I was going to remove the exhaust manifold - but as the bolts on this look like they haven't been moved in 36 years - I'm not sure if they will come off. Is therr another bolt and if so where :rolleyes:
BB5000
1975 Mercedes 200 with 5.0 M117
There are two bolts holding the starter to the bellhousing if I remember rightly. One at the top, and one at the bottom. ;)
T
tomadaly
cork, ireland
450SL - 1973 - auto
Thanks - At least now I know that beating it with a lump hammer won't budge it -- any idea where the bolt is - I can't feel it , see it or have any idea what to remove to get at it ??
Alex Crow
Super Suffolk
oh dear. it is there, diametrically opposite the first (at the top). not easy to get at, presumably you are working on the ground?
T
tomadaly
cork, ireland
450SL - 1973 - auto
I have the car up on stands - still means crawling under it. I've tried feeling around but can't feel any bolts - seems to be very little room at the top. The one I got at was on the bottom. Has anyone removed the started and what did you have to remove to get at the top bolt ??:confused:
osc
1971 450SL; 1989 911 3.2 Carrera Targa; 1999 BMW 728i
i have done it, with the engine in situ so it is doable.
it helps to feel around if you can get all the muck off it - suggest degreaser and a pressure washer
link not of much help - its just like AP said - but here you go anyway
http://www.detali.ru/cat/oem_mb2.as....701&VIN=*&CT=M&cat=043&SID=15&SGR=045&SGN=03
i think you need a lond extension socket to get in and a lot of patience
when you get it loose mind your head because its bluddy heavy, esp when lying upside down
good luck
Alex Crow
Super Suffolk
yes it can be done, a very long extension from the rear of the autobox is needed. but if you cannot even get your fingers to it that will be difficult, have you had a look from above to see if you can see it between the block and the bulkhead?
T
tomadaly
cork, ireland
450SL - 1973 - auto
got it - finally - thanks for all the help.
The bolt on the top was there - behind lots of engine gunk and out of sight from below the engine. The secret is to get at the bolt from the back of the car - along the exhaust pipes. I managed to raise the car another couple of inches which meant I could get at the bolt with a long socket extension and a knuckle joint. I have left the socket on the bolt head - as i hope this will make putting it back in easier.
Alex Crow
Super Suffolk
well done, not too bad with the long extension is it.
Tel: 020 8863 9233
