R129 - changing a warning light bulb
They just push out from the rear, you can use hooks but that glass is £175
lanciaman
lanciaman
Aberdeenshire
E220 Cabrio (A124) - 1994
Thanks Malcolm. No clips or bits to unhitch? Just give it a shove?
Lindsay
Yes correct,, just run a flat bladed knife all around to free it off in case it stuck.
You will have to remove the rear cover to replace the main bulbs
lanciaman
lanciaman
Aberdeenshire
Ok. Sounds simple enough in theory!!
Many thanks - once again!! :D
The bulbs are MB special 2w for the main lighting and 1.2w for the tell tail lamps
lanciaman
lanciaman
Aberdeenshire
MB only?? oh fun and games there then! Actually my local dealer (40 miles away) are very good at sending parts to me in the post so should be ok.
cheers Macolm
If the 1.2w small tell tale lamps the the Ring RU509T will do but you have to squeeze the contacts closer together with a pair of pliers
You will have to take the steering wheel off, push or pull the cluster of evenly. Hope this helps
Yes that could be the case, I had the electric steering adjustment ;)
lanciaman
lanciaman
Aberdeenshire
Thanks chaps. Mine has the electric steering adjust also so hopefully won't have to take the wheel off! Or put another way, I am not taking the wheel off so the duff bulb will need to stay put!!
It will come out with that :D:D
lanciaman
lanciaman
Aberdeenshire
Hi Malcolm. Good news. Still waiting for ETA to come back from the chap in the US- he is in NY so although job done (rewired, new potentiometer) he can't post it back due to storm chaos. Will update once back but I am hoping and fairly confident it will sort the damn ASR issue which has plagued my R129!
It will be nice to have a fix on this fault for all of us :D:D
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
I watched the video on his site where he is testing your ETA :)
lanciaman
lanciaman
Aberdeenshire
Have to say he has done one thorough job on it. I'll give a full report under a proper title once it is back and installed but he has rewired it, tested the coil (which can go apparently), changed this potenitometer - then redid it as he wasn't happy with the way it was sitting. Left it running for 12 hours to make sure no overheating then plugged it into a test SL to make sure it was working A1. So, I think we can assume if the fault remains then it isn't the ETA!
