R129 Charcoal Cannister Location
CMC
Sheffield
SL 320/1997/3.2
Can someone advise where the charcoal cannister is located on a 1997 R129.
Thank you
rayhennig
1991 300CE-24 Sportline
My guess would be under the left hand front wing. Possibly accessible by removing the inner wheel arch lining.
That is the case for my 124.
RayH
C
CMC
Sheffield
SL 320/1997/3.2
Thank you I will give it a try.
C
CMC
Sheffield
SL 320/1997/3.2
I haven't had time to check but will do it at the weekend.
C
CMC
Sheffield
SL 320/1997/3.2
I had time to check today. The charcoal cannister is located under the left hand side wing. To access remove the wheel and the wheel arch lining.
rayhennig
Yes, that is what I recall on my 300CE. How easy is it to get to the canister? Mine was replaced by the garage.
R
C
CMC
Sheffield
SL 320/1997/3.2
I was getting fuel vapour smell in the interior. I suspected the charcoal cannister, After getting access to the area I did try to remove the cannister but couldn't work out how it is unclipped. It is in a confined space. Then I noticed one of the rubber hoses was split. This was repaired and the problem solved. In the end removal was not required.
Thank you for your help.
DREAMER NO2
W124 2.6E M103 1989
.First jack up the car remove the front wheel . And then find and remove the 6 or more plastic nuts,, .to remove the wheel arch lining .Do a little cleaning while your in there and spray inside with a wax nhibitor. Before replacing the w/a/ cover
C
CMC
Sheffield
SL 320/1997/3.2
Thank you
