R129 headlight washer / wiper system
Inglewood
Farnham, Surrey
Now enjoying my R129
Just picked up my 1998 SL500 and can’t find any proper reference in the various manuals on how the headlamp wiper system works?
With lights on only etc or if the windscreen is cleaned 3 times of more at the same time etc?
Do they fail and if so what’s the most likely reason?
Oh, and blades are stupidly expensive!
Inglewood
Inglewood
Farnham, Surrey
What’s the betting the motors won’t work when I try them for the first time
Pretty hard to see from the driver's seat unless it's dark (then you'll see a shadow move across the light pattern).
Wearsafoxhat
Sunny Hampshire by the sea
Park somewhere so that you can see the reflection of them. Yes last time I enquired about the blades they where £25 each. It is fairly easy to replace the rubber though, cut up a new blade and the steel insert bit and fit that.
Do not be tempted to crimp the plastic end, it snaps
Inglewood
Inglewood
Farnham, Surrey
The wipers work but not a drop of fluid in sight - where does the water come out of the arm?
There's a small hose feeds water in.
Does the pump run (different pump to main washers if I recall correctly).
Inglewood
Inglewood
Farnham, Surrey
Not sure but I will try and check it early next week
Wearsafoxhat
The drivers side wiper controls the washer, with the wiper at rest, home position it will isolate the supply to the pump.
Yes two pumps on the washer bottle.
The tubes could be blocked, dis-connected.
Inglewood
Inglewood
Farnham, Surrey
Time for Star at Reading to sort it out I think
Wearsafoxhat
Before you head off to Reading why not dis connect a pipe / hose from the pump on the washer bottle and have someone test it whilst you see if any water comes out, if the pump makes a sound.
Could just be a blocked pipe.
Not trying to do Star out of any work but some things are quite easy to look at.
davidsl500
Home : Derbyshire at the moment !
R172 250CDI Gone..!, R129 SL500 Gone...
Mine wouldn't shut off spraying water at one time and i had to disconnect the wiring plug. Turned out to be an N10 combo relay issue which got sorted when the main wiper started playing up...
