R129 seat only moves forward
Rossco1962
Portsmouth / Gosport
320 sl R129 straight 6 1995
Hi My R129 320 failed its MOT as the seat will only move forwards when controlled by the door switch. if i push the back button there is another motor in the back rest that starts moving so i took the belt off that.
I've cleaned the door switch with contact cleaner and also swopped over the switch from the passenger door but it still doesn't function correctly
Any suggestions
RossCo
Broken wire in door harness near hinge maybe...
Does it move on the memory buttons?
R
Rossco1962
hi thanks there are no memory buttons on the switch. when the back button is moved the motor in the back rest operates instead
I have never seen a 129 without memory seats!
Garista
France
2001 ML 270 CDI. 1991 R129 300 SL
My 1990 300 SL has no memory seats. To replace the switch is expensive.
Just a thought but it is possible to put the connectors on the door switch on the wrong terminals.
