R129 SL
toby1
West Berkshire
is this "SL Tax"?
[like RS tax on fords, anything that comes on an RS doubles in value on ebay even if its on other "lesser vehicles"]
Not sure what you mean (I know what the RS tax is). It's a model toy; I assume you know that but it's unclear! ;)
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #122
My 91 model has aircon, with blue/red indicator on the dash vents, cruise, adjustable steering wheel, no airbag, 5-speed box, and all the cubbies lock with the central locking. Two-phase heated seats are ace :)
Hope this helps
Jon
cheers John, is yours a manual? and what engine is it? accordign to what i remember the 280 and 300 came with manuals as standard where as the larger engines were Auto only...
toby1
West Berkshire
Never knew you could buy a 129 with a manual box - every day's a school day
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #125
hahah!
i need a V8 so that eliminates the option for me. and i'm sure there would be rare, i havent seen an R129 for sale
5 speed auto in a 1991? was it a retro fit?
i was saying that because it was related to a "Mercedes SL" that it was expensive, like anything with an RS badge generally is [unless its a Rs1800 fiesta then nobody knows what it is, but its still overpriced for a mk3 lol]
i knew it was a model :p
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #127
No, it's on the build sheet so must have been an option.
interesting.... i wasnt aware that the 5 speed existed in that year...? is it the same box as they put in the 500E? was that a 5 speed auto?
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #129
interesting.... oddities like this [if it is such a thing] interest me a lot :)
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #130
so,
been continuing to look at SLs, and i'm planning on going down to Bridgwater to have a look at one between christmas and new year.
i may go have a look at one in stafford, but it has ADS and i've pretty much decided that i want to avoid it.
Yes a wise move with ADS.
Re the gear box the 722.5 a box with an electric 5th gear was added or an option to some models only from mid 1992 till 06-96 when the 722.6 standard 5 speed box was introduced
jonthetourist
Glos
www.cypruspropertyvillas.com
1991 SL300-24
Malcolm mine is a 1991 and it was on the build sheet. That's the only data point I can contribute ;)
Jon
Jon
OK it may have been earlier on the 129, and thank you for that, yours must have been one of the first with it :D
Just remembered it came along I think at the same time as the 24v engine
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #134
Electric 5th gear? please explain i dont understand
teabag
North East England
2001 W163 ML270 CDI
It's an electronic overdrive unit mounted at the rear of a four speed autobox, it comes in automatically if you leave the lever in "D" but can be over ridden if you move the lever to "4".
I have one fitted as standard to my 93 320CE and it works well, but I've just had to have the box overhauled and reverse gear B3 band and Piston replaced at 110,000 miles.
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #136
sounds expensive
teabag
North East England
2001 W163 ML270 CDI
sounds expensive
It wasn't cheap and something I did not bargain for when I bought the car, but £800 including removal and refitting isn't all that bad when you consider the company who did the work tell me to expect another 100,000 miles out of the gearbox as when inspected it was found to be in perfect working order apart from the reverse gear problem which had probably been caused by a previous owner slamming it into reverse before the car had stopped moving forward.
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #138
I have made a purchase.
i will post in the photo forum when i get chance.
You are keeping us waiting too long :(
