R230 Central Locking /boot soft close not working
merk350
Newcastle
SL350 2005 with pano roof
Hi ,
Just been for a drive out today ,boot soft close was working fine before we left .Parked the car up locked it ,came back to the car about 1hour later and could not open the boot, boot release inside the car would also not release the boot, also central locking will not pull down the door buttons .
Got home managed to open the boot with the key checked all fuses under rear storage box and bonnet non of them seem to be blown.
I can close the boot bit it will not latch down fully so the red indication of "close boot lid " comes on also roof will not open as it thinks boot is still open .I have also had the "close boot separator warning" even though it is closed .
Is it PSE time or is there some thing else that could be a miss.
Hopefully something simple :(
merk350
Newcastle
  • #2
Managed to lock the boot fully with the key but the roof will still not operate message of "close boot separator " on dash even though it is closed.
Could it be the switch in the separator latch causing the problem?
Still no joy no central locking or soft close?
Any ideas anyone
Sounds like your PSE pump has failed. Check under the boot floor for water - any boot leaks will eventually drown the pump.
merk350
Newcastle
I checked under boot floor ,also I have re done all window seals a while back and no leaks evident.
Can these be repaired or is it ££££s time.
There was someone posted the other day about getting theirs rebuilt for £450 or so.
merk350
Newcastle
If the system has a leak will this stop the pump working?
A leak could cause it. Normally you'll hear it hissing.
merk350
Newcastle
Ok ,checked again under the pump no water,disconnected the pump and reconnected, gave it a tap and I get a whirring noise for a second then nothing, no signs of any air leaks,the lumbar function also is not working so it looks like it is the pump.
Just to summarise
No Central locking
Boot soft close not working.
Lumbar on both seats not working.
Just before I go down the ££ option of a new pump,is there anything else that works of the PSE pump or is that it.
I think (but can't swear to it) that the heater vents are also vacuum controlled (or is it just 129s?) Pretty importantly the fuel filler unlock also works from PSE.....
Given the list of items that don't work I would say it pretty conclusive.
merk350
Newcastle
Thanks for the quick reply, the fuel filler still opens fortunately,I thought about this last night but tried it today and it opens phew.
drmw
Yorkshire
www.autonomed.co.uk
If the pump makes any noise it is not likely to be it "in the conventional sense". If you try a few times it would pop the fuse - if it makes a noise, it hasn't. See if the petrol cap locks - if it does, then it isn't likely to be a "replacement" - need to keep digging.
merk350
Newcastle
I can open the petrol flap just by pushing it in and it pops open, tried all fuses yesterday all ok.
Dont know where else to check.
I can't open the roof either warning saying "close boot separator" this is probably because of the soft close function not working.
Mercedes of Edinburgh have an E Bay shop selling pumps for £675 delivered with 2yr guarantee compared to £900 + at the main dealer parts counter.
merk350
Newcastle
^ that’s a decent price
Yes thats what i thought £300 cheaper mercedes of perth also has an e bay shop they are charging £745 also with 2yr guarantee
Sent from my SM-G935F using Tapatalk
The only thing we don't know (and probably don't want to test) is whether the pump also locks the fuel filler cap - its possible its never locked it!
merk350
Newcastle
Yes not a good idea, just booked it in to the local indie seems to think the pump has a partial failure,
drmw
Yorkshire
www.autonomed.co.uk
Does the petrol flap stay unlocked when the car is locked?
merk350
Newcastle
  • #19
I have to lock the door with the key but the flap stays unlocked
drmw
Yorkshire
www.autonomed.co.uk
That is even more odd. I shall have a thought
