R230 Central Locking /boot soft close not working
Are your internal compartments locked (glovebox, cubbies, door pockets)?
M
merk350
Newcastle
SL350 2005 with pano roof
  • #22
Will check them later,out at the moment
Sent from my SM-G935F using Tapatalk
M
merk350
Newcastle
  • #23
That is even more odd. I shall have a thought
Just checked when doors are locked manually with key fuel fill cap can be opened also all cubby boxes stay open ie can be opened manually .
Going to check fuses again tomorrow as weather is poor now.
I have ordered pump from MB Edinburgh (E bay shop) coming this week and having indie fit next week,unless I can find another problem that is causing the fault,then I can return the pump just have to pay return delivery.
star
Reading
Smart + others :)
Have you tried pulling the fuse for a minute, then retrying boot. It’s a common fault with soft close on boot.
That definitely suggests there is insufficient vacuum/air from the pump.
One possible cause is if the pump impeller has broken up - there are eBay kits for this.
drmw
Yorkshire
www.autonomed.co.uk
I'm afraid I don't buy the pump - the answer was in the whirring noise. I have three R230s, four pumps and when it went, it went - no "gave it a tap and I get a whirring noise for a second" 'cos they all blew the fuse. If it hadn't been for that one fact I would agree! Time will tell ;-)
M
merk350
Newcastle
  • #27
I thought about trying to do this,but not sure how complicated.The pump impeller kit is £180 .I have the details of the guy who repairs them,but decided to go with a new pump with a 2yr warranty.
I will keep you posted on my progress.
M
merk350
Newcastle
  • #28
Going try again tomorrow morning
M
merk350
Newcastle
  • #29
Its not just the boot soft close that is not working its the central locking and lumbar function as well.
Will try this anyway thanks.
star
Reading
Smart + others :)
Thanks, sometime do go to beginning of thread.
M
merk350
Newcastle
  • #31
Ok checked fuse again today it was a 25A that was fitted and ot had blown which is strange because when I initially checked it was ok,dont if it was when ive been checking the pump in the boot.
Anyway replaced fuse and it didnt blow but still no c/ locking etc
M
merk350
Newcastle
  • #32
Indie fitted new pump yesterday all sorted everything back to normal £30 to fit and code
The 25A fuse blowing is a common symptom of a failed pump.
Glad you got it sorted.
ajlsl600
france
is therenot a coupling in the pse pump? if so maybe that failed and motor is running ,driving nothing . or has it just disintigrated internaly . everytime i go out ,i hold my breath suspect plenty R23 owners do same. i am looking at marlin or YCK roadster for summer,simple driving .do my biggles impression with lovelly and mut!
M
merk350
Newcastle
  • #35
Just holding my breath that the sbc is ok
I think the impeller self destructs internally and jams the pump. From memory they're made from graphite so as to be self lubricating.
M
merk350
Newcastle
  • #37
Going to dismantle old pump ti see what the problem was
ajlsl600
france
as seen my keyboard at times dont display e letter i press.wot to do, however most got the idea.....
if its alraedy screwed ,nothin to loose by interviewing it,sometimes much to gain. go for it .
as sn my kyboard at tims dont display lttr i prss.wot to do, howvr most got th ida.....
if its alrady scrwd ,nothin to loos by intrviwing it,somtims much to gain. go for it .
Fixed that for you Andy;)
