R230 door mirror indicator replacement
Malcolm Johnson
East Yorkshire & Suffolk
R230 (M273) & W221 S350 bluetec
Hello all,
how easy will it be to replace the indicator strip inset in my door mirror casing.
my local indie quoted half a hour a side, easy or a fiddle ?:D
This depends on the year of the car, the early 2002 were pigs, later ones dead easy
The 2003 mirror you remove the glass, remove the mirror motor drive, remove the 3 screws holding the cover on and that is it.
M
Malcolm Johnson
Cheers Malcolm,
The girls Dec 06
Then as above :D If you feel happier with the instruction I can let you have them
