R230 rad fan not working
consort
East Malling Kent
Punto Grand Evo Esssee, ML300, TVR 4.5 Cerbera
The radiator fan is not running and consequently causing the engine to run hot on my SL 500 R230.
The fan runs when the a/c is on and so I would imagine that the water temp sender unit is at fault.
Would anyone on here be able to enlighten me?
Out of interest, but I am sure not connected, but my heater control instrument cluster sometimes dims, and I have no hot air coming out of the screen vents.
Thanks for any advice.
This could be damp in the near side SAM if the fan cannot be found, I will take a look at the wiring diagrams later in the day.
Alex Crow
Super Suffolk
How hot does it get?
Is it only a problem when stationary/moving very slowly?
You have relay K25 and f49
C
consort
East Malling Kent
The car always runs at 80 degrees. Now creams up to just below 100 when stationary. I am still getting some rad cooling by the fan when the a.c is on to cool the condenser. No a.c then the rad fan does not run.
I think that is correct :D 1 day we may get a car where the actual fan has packed up, not in your case as it does run
Gkinghorn
Bournemouth
E350 CDI Cabriolet - 2011
I worry when mine crawls up to just below 90 when stationary in traffic on a hot day (to be expected) 100 would really bother me ..but yes x80 is about normal in m view..
100c is a very efficient temp for the engine, my 1928RR would have hardly any power under 100c
reflexboy
Surrey
E350CDi Sport&R172 SLK250CDi AMG Sport
On a cold day mine will sit at a needle's width over 80. In traffic it will be about 90 and I can hear the fan cutting in and out OK. Driving on a warm day it will be about 85ish. Sitting on the motorway it will be just over 80
C
consort
East Malling Kent
Yes throughout 7 years of ownership, (never owned a car for so long) it has always been spot on 80 even in the heat of summer.
C
consort
East Malling Kent
sorted
Many thanks. I tracked the problem down to a faulty water sender. £8.95 on e bay for a new one. All fixed and nice and cool.
