R230 SL: Running cables from boot into cabin - best/easiest route?
gez
South Coast
R230 SL350; R231 SL400 (SOLD), W211 E320 CDi Estate (SOLD), R129 Brabus SL500 (should not have SOLD)
I have found that using the centre console power outlet to power my phone holder and dashcam interferes with DAB reception so I need to relocate my usb adapter to the boot power outlet. I'm also installing a reversing camera and rear dashcam.
So I have a number of cables to route from the boot into the cabin.
I had a first pass go and found a route but it proved too close to the roof mechanism hinges and would likely snag the cables over time so I decided to back off from that idea.
Rather than attack the trim until I find a gap I'm sure others have done this and might have recommendations?
ajlsl600
france
Try the sills and following the harness and can wiring. Ensure you are well shielded to avoid interference with existing.
G
gez
South Coast
It's getting to the sills that is the problem.
I will have no problem in routing the cables once I can get them through the boot bulkhead into the cabin.
ajlsl600
france
I seem to remember? The outer sills come off, can you not see a route then? If existing cabling if entering and departing there.
ajlsl600
france
Is!!! Finger in pencil sharpener time a f gain..
G
gez
South Coast
Thanks, I'll check it out and post some pics when I find a route.
