rear camera u/s
davsop
Midlands
S350 Bluetec 2011 w221
Hi all
Just a couple of questions. On my 2011 S350 the rear camera has gone u/s. Can you recommend a solution? I'm in the west midland.
Also, noticed my sat nav wasn't displaying up to date roads. Does mercedes charge to update the navigation when in goes in for servicing or do you have to ask?
Many thanks.
Botus
S500/2010/500
merc will charge to do anything
I'd find a competent independent to look at your faults. more competent and half the proce
they might be connected, sat nav I presume you mean its not showing current position correctly? this is a std fault on merc the nav antenna goes wrong there are cheap ways to resolve
davsop
davsop
Midlands
Thanks Botus
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
Check where the cable follows the boot hinge on the left hand side for the camera cable. Mine had worn through and broken a core. A quick solder and wrap job sorted it
davsop
davsop
Midlands
Thanks Barry I'll take a look.
