Rear-End Wizards
tuckburg
Joshua, Texas
My 78' 300D leaking ravishly on rt. rear cv boot @ wheel side ?? Common sense says replace boots only. Does anyone know if it is possible to purchase seperate, or should more be done given unknown amount of time leaking and damage done. Shifts up and down smooth.
Tucker
"It is so frustrating to hit a wall that one can only see over, but not get threw. But how satisfying and rewarding the freedom can be when all get threw."
whitenemesis
CLS55 AMG '05
Tucker
Again, in english?
T
tuckburg
Joshua, Texas
My drive axle leaks at the outside boot of my rear wheel car, it starts to do this after you drive. I have gotton down and seen this. It has weathered and sprayd a rotaition ring onto frame underneeth car. worried about axle grease, somethings comming out and nothings going back in(fluid). Normal? Change 1, both? Hopefuly not entire unite? Sorry so confusing.
whitenemesis
CLS55 AMG '05
Sounds like a rubber boot has split/loosened.
They are replacable seperately. I would suggest replacing both sides and topping up the diff oil.
Find your model here and check out the parts;-
http://www.detali.ru/cat/oem_mb0.asp?TP=1
T
tuckburg
Joshua, Texas
Thanks alot whitenemesis,
I will get right on it. It just started and it is making a mess. Sorry for th confusion earlier.
whitenemesis
CLS55 AMG '05
Good luck, let us know how it goes :D
www.ckinsurance.co.uk
