MissyD
- Mar 16, 2008
- Location
- Essex init
- Website
- www.depop.com
- E200 1993, E300 Coupe 2019
When I washed my car today, I noticed that the rear passenger door panel was loose. Is it just a matter of pushing down on the clips and then the panel will clip back in or is it more complicated than that?
It has been off and they have not 'pushed the door card/panel down' sufficient to locate the clips in the door plate. You may, but I somehow doubt it, be able to push down on the card however to do it correctly take out the screws from the door card and relocate it then re fit the screws etc Check our your motor on the attached-
http://www.detali.ru/cat/oem_mb0.asp?TP=1
The top of the card must engage in the top of the inside of the door, and the card should be removed to do it properly.
I may have a how too paper
