rear SAM
all rear lights
rear washer
power boot motor
fuel gauges
Alarm siren
reversion camera
overhead control panel
and a few other bits.
bembo449
bembo449
gainsborough , lincolnshire
Looking for more SAM unit info , i spoke with Alex earlier ( thanks pal ) we agreed there was a com issue but many brains make for more ideas right ?
So currently this is whats not working on the GL320
Horn , wipers , indicators , loads of traction control related things DSR etc , and the fans on the engine are running whenever the car is driven , it does run and drive fine bar the above , biggest issue is it will not communicate thru OBD which is a real pita
Sorry, my day was not good today, after 10+ hours on a fing wheel speed sensor fault! Call me tomorrow at your convenience
I’d be looking for water ingress :(
bembo449
bembo449
But where pal , rear sam defo had water on it , front ones mint , if we can confirm all the above not working items are controlled from the rear sam then it obvs needs a new one ! Assuming the sam units on these MB dont lose the code if disconnected???
Uncle Benz
West Sussex
Mainly Mercedes
Hmm, sounds steering column module to me, but OBD down is a concern
Have you checked the K line fuse?
bembo449
bembo449
Alex , you dont have any apologies to make pal , im grateful you even take the time to talk ☺️
bembo449
bembo449
Ok , all the fuses in the engine bay are ok but not fully looked at others , so many things not working is usually a sam issue
If it had water on, get it opened up and look for damage.
Uncle Benz
West Sussex
Mainly Mercedes
All the things you mentioned can come from steering column module
bembo449
bembo449
I did pal , contact cleaner and toothbrush, did fit a spare one bit if anything it was worse ! Cant say there was any significant damage , BUT if all the things not working are power / control by the rear sam then it stands to reason it needs a known good one coding in OR a new one coding in from MB
I’d be looking at @Uncle Benz advice above first
Uncle Benz
West Sussex
Mainly Mercedes
Including the engine fans ? Blimey
No, that’s from the K line down. Don’t rule out nervous chatter from the faulty unit filling the canbus so nothing else can get a word in. Engine ecu will run the fan full speed if it can’t communicate with anything else. Could be to protect the engine, could just be a tantrum thing, but they do do that.
