Rear seat stuck W203 estate
KingsC320
Bristol
C320CDI
Hi all, im new around here.
I have gone to fold the larger section of the split rear seats and it is stuck solid, with the luggage cover firmly in place!
The release handle has a bit of resistance, so I don't think the cable has unattached itself but possibly stretched.
I have been searching the forum for others who have had the same problem on the W203 but have come up blank. (found lots of e class with the same problem)
Would getting to the release mechanism be very similar on the e class as my W203, so I can make a start at tring to fix it.
Any help/advice would be appreciated
Alex M Grieve
Broom, Warwickshire
Hi all, I'm new around here.
Hello and welcome to the Forum.
Your problem has been discussed quite recently on the Forum, so I don't know what key words you used on searching, but it would be worth trying more - search seems to be quite specific in my experience!
Hopefully some of those involved in the last discussion will join in to help.
K
KingsC320
Bristol
C320CDI
On further inspection last night, the secondary locking mechanism on the hinge by the armrest seems to be releasing ok, but the main catch is still stuck.
I will try and get some info on this if the fault is listed
K
KingsC320
Bristol
C320CDI
I appreciate any help you can give, the last thing I want to do is take it to the stealers and get bent over!
rpe2
Silchester
Have you folded the small section of the rear seat first?
If not, if the luggage cover is in place, you will need to fold the small seat section first, allowing the larger section (to which the load cover is attached) to fold.
whitenemesis
CLS55 AMG '05
Good call, this caught me out when I first had the car :Oops: :)
K
KingsC320
Bristol
C320CDI
Have tried with small section folded, still will not move.
In looking at the small seat catch mechanism (as i've managed to remove the handle pull surround) to see what parts should be moving, that has now stuck fast in the upright position!
Thanks for the links, have already had a look at them to get some ideas.
I have put some WD40 down into the mechanism to see if that will free anything up (wishful thinking, I know!) before I start to remove the seat leather and carpet.
As the luggage cover is firmly in place, has anyone got an idea how you can fold the fabric on the back side of the rear seat (ideally without cutting it) to be able to gain access to the mechanism?
I've only had the car a few weeks and its reduced carrying capacity is starting to annoy me :(
I will look this evening to see if there is anything that will help
I have quite a lot of info on this but I cannot print it off for a few days
whitenemesis
CLS55 AMG '05
I can't find anything that doesn't start with the seats folded....
Info on removing the covers and replacing the cable, it is a matter of using the info so that you do the least damage, once you know where all the fittings are it can make a difference, there is nothing else to be had
K
KingsC320
Bristol
C320CDI
I've managed to get the seats to fold!
The only problem is I now need 2 new catch mechanisms! The only way I could see what was wrong was to break the handle to gain access to release the vertical rod to the catch.
Jeffj
Registered
C-class/2004/1.8k
Hi everyone.
Did anyone have any luck doing this without breaking the handle? I also have the same problem. The larger section center catch is releasing, however the catch next to the door will not.
Any input at all is greatly appreciated.
jjayp
LONDON
C230 2.5 Estate 2006
Sorry for Bumping this but I'm struggling here. C230 2.5 estate, jammed passenger side rear seat release. Pretty identical to all the others, drivers side releases fine, it's only a toggle lever on the top of the seat, passenger side the seat is is locked in place but the indicator is still up. There is tension in the toggle lever so it's not likely the cable is broken. Any suggestions except for sledgehammer or kicking the living daylights out of it.
jjayp
LONDON
Has the seatbelt got caught in the mechanism?
I’d be tempted to give it a really good shove backwards to get it to lock. Wouldn’t be the first time somethings got caught in it stopping it closing :(
