Rear suspension
Ben Jackson
E220 SE 125 Edition Blue Efficiency
Hi, just wondering if anyone can help? I’ve got a 2011 E class estate which has been dropping on its rear air suspension. It only happens on the near side rear. I initially thought it was a leak, but it doesn’t go down in a consistent manner. Sometimes it’s fine for days, other times it will go down every night or when left for a few hours. Occasionally it will go down in front of my eyes, especially if it’s parked on slightly uneven ground. Perhaps it could be a sensor? Thanks.
Hello and welcome
Leak in the bag is likely and it depends how it sits as to whether it leaks or not.
Spray some soapy water over it and the connections and see where the bubbles are coming from.
It’s a common enough issue and there are quite a few threads on here with the issue
00slk
Cambridgeshire UK
Been there done that.............Mine did the exact same as how you have describe. Fitted 2 new airbags and the cars been good. Once the bags are off you can see the thinning of the rubber where the air escapes from. Always replace as a pair ;)
B
Ben Jackson
Thanks for your help! Looks like a pair of new bags is in the cards..!
merc85
HARWICH
E320 cdi
I think Arnott do them too
