Not_Anumber
- Jan 23, 2022
- S212 E350cdi prefaclift
Hi, Im hopefully rejoining th ranks of Mercedes owners soon having been offered a S212 E350cdi estate. Its pre facelift, I think a 2012 or 2013. . Ive had several Mercs previously, W124 estate, W124 coupe, W126, R107 and lastly a W210 estate before somehow ending up with an Audi A7. Time to make amends I think.
It has Buleefficency badges on the side, AMG line type wheels and front seats but couldnt work out what spec it is. Stupidly I didnt make a note of the vin number when i drove it, is there anyway of finding out the trim level from the registration does anyone know ?
The only things that are making me hesitate are:
I couldnt find an audio aux input or a slot for playing mp3s from USB sticks or SD cards. There is a proprietary socket in the box under the armrest but nothing plugged into it. Does anyone know if there are adapter leads available so I can plug USB sticks into this please ?
Is it easy to get used to the column mounted auto gearchange ? At first sight it seems a bit awkward to use after a standard automatic stick shift with it's separate button on the centre console to change between S and E modes.
The tailgate opens nicely from the key and the switch on the drivers door but these wont close it, that can only be done from the button on the underside of the tailgate itself. Does anyone know if this can be DIY reprogrammed to close from the key ?
Does anyone know how many bhp the 350 blueefficiency is please ? Does the blueefficiency mean this is an detuned 350 compared to a standard E350 cdi ?
Im not sure if it has DAB radio. If not is it practical to DIY upgrade ?
Are updated Sat nav maps available at reasonable, non dealership, cost
Has anyone upsized the standard COMMAND/Satnav screen. Were larger ones available in other spec cars that could be swapped across. Ive got too used to a larger screen.
Chris
Chris
