rejoining Merc ownership, questions
Not_Anumber
S212 E350cdi prefaclift
Hi, Im hopefully rejoining th ranks of Mercedes owners soon having been offered a S212 E350cdi estate. Its pre facelift, I think a 2012 or 2013. . Ive had several Mercs previously, W124 estate, W124 coupe, W126, R107 and lastly a W210 estate before somehow ending up with an Audi A7. Time to make amends I think.
It has Buleefficency badges on the side, AMG line type wheels and front seats but couldnt work out what spec it is. Stupidly I didnt make a note of the vin number when i drove it, is there anyway of finding out the trim level from the registration does anyone know ?
The only things that are making me hesitate are:
I couldnt find an audio aux input or a slot for playing mp3s from USB sticks or SD cards. There is a proprietary socket in the box under the armrest but nothing plugged into it. Does anyone know if there are adapter leads available so I can plug USB sticks into this please ?
Is it easy to get used to the column mounted auto gearchange ? At first sight it seems a bit awkward to use after a standard automatic stick shift with it's separate button on the centre console to change between S and E modes.
The tailgate opens nicely from the key and the switch on the drivers door but these wont close it, that can only be done from the button on the underside of the tailgate itself. Does anyone know if this can be DIY reprogrammed to close from the key ?
Does anyone know how many bhp the 350 blueefficiency is please ? Does the blueefficiency mean this is an detuned 350 compared to a standard E350 cdi ?
Im not sure if it has DAB radio. If not is it practical to DIY upgrade ?
Are updated Sat nav maps available at reasonable, non dealership, cost
Has anyone upsized the standard COMMAND/Satnav screen. Were larger ones available in other spec cars that could be swapped across. Ive got too used to a larger screen.
Chris
Hello and welcome
SmartAmg
2011 E class coupe 350 CDI
Welcome, Chris. :)
dry run
Portsmouth
kb-boatpark.co.uk
CLS 350d AMG LIne Premium Plus
Welcome :)
Column shift comes naturally after a little time. Don't thimk Bluefficiency models have any less BHP than others. Sport/AMG-line models will have paddle-shift and ali-look pedals, as well as some side skirts and front spoiler.
I'm sure some bright spark on here can tell you how to get the build sheet from the VRN, but that person isn't me :(
  • Like
Reactions: DSK
N
Not_Anumber
Thanks for the advice. The column shift worried me a bit. It looks like there are adapters available to play mp3s from USB sticks which was one of my sticking points. I will get hold of the VIN later today so should be able to find out a bit more about the car. Very many plus points and my current car has done so many miles I really should move on before it becomes worthless.
Im 90% decided now. Just the lack of DAB and the small size of the COMMAND/ Satnav screen are the only downers for me.
It is very hard to resist going back to a Mercedes again, especially when it looks this good.
00slk
Cambridgeshire UK
Hello and welcome
Hi and welcome.
If the connector looks like this then you can get usb adaptors cheaply and easily or even Bluetooth audio ones.
Are you sure you can't close the boot from the inside button? Pull to open, push to close.
That's the way the tailgate on my 61 plate R class works
N
Not_Anumber
Thanks LostKiwi, thats greta another doubt sorted, it does have that connector in the armrest. I only viewed the car briefly so didnt realise the inside release button pushed down as well as up, excellent
A.J.
Norwich. UK
Hi Chris welcome to the forum :)
Gazwould
C250 CDI
I like the S212 in darker colours as it hides it's bulk , I looked quickly and thought it was a S204.
Only issues with that one is tinted 3/4 as opposed to factory option privacy glass and diamond cut wheels.
