Remapping the E63 at MSL
AMGeed
Poole, Dorset
S204 C180K
I finally got the E63 to MSL today for a Stage 1 remap, dyno and resonator removal at Torqueflow.
Arrived a little early at 8 15am in Birmingham after a longish run up from Poole, Dorset. Quite pleased with the mpg seeing I wasn't hanging around and had a clear run without traffic.
Acid was there and put the car straight on the dyno to get an idea of the stock figure and condition of the engine. It was serviced in Sept and apparently needs a drop of oil soon. I'll keep an eye on the level as I hear some of these M157 Biturbo engines do use some oil between services.
An MSL photo of the car on the dyno, unfortunately covered in road grime after the run up in the rain. It was spotless when I left! 75362337_2753367398035377_4231357245503307776_n.jpg
After the first run, it was shown the engine is making over the claimed figure of 557bhp as it came up at 490bhp at the wheels which equates to 572 bhp at the flywheel, the figure most use when relating the cars bhp. Torque too was strong at 503 ft lbs which again is 593ft ft lbs at the flywheel.
After cooling down, the map was put on and the first run gave a strong figure of 565bhp at the wheels, or 666bhp at the flywheel. The torque increased to 657 ft lbs which is 775 ft lbs at the flywheel.
Acid explained he would prefer to leave the map running this amount of bhp to conserve the longevity of the engine. If I wanted 700bhp, he would give it, but I thought 666bhp is more than adequate. I'm not chasing huge figures or tracking the car, just giving back some of the power held back by Mercedes. The speed limiter was also lifted should I fancy a fast run on an autobahn.
A photo of the Power runs on the dyno. Multiply all the figures by 1.18 to cancel the powertrain loss and the figure the engine is producing. The figure in Red is the pre map figure, the blue one mapped. 20191116_103922.jpg
The car was handed over to Imran who was removing the resonator to increase that nice V8 sound, especially the cold start. All finished by 1 30pm with break for a chicken dinner (thanks Acid)
Here is the man at work.
Was it worth it? Damn right it was. Its a lot quicker off the line and the power from 50mph + is incredible. Its a real licence loser if you aren't careful.
As for the exhaust, love it. But my next door neighbour is going to hate me. I'd say its 50% louder, and you can't help grinning at the downshifts when braking in Sport +
It does need a slip diff to put the power down, and despite having 19" rims, the gap in the arch is too big, so it needs H&R lowering springs and rear links. Then its finished. I won't be doing anything else but enjoy driving it.
Wearsafoxhat
Sunny Hampshire by the sea
A good day out then, glad that you are suitably impressed with the out come.
I’ll await the next video.
AMGeed
AMGeed
Poole, Dorset
S204 C180K
MSL posted this dyno video of the car on Facebook.
When this was finished, it went to Torqueflow for a resonator delete so its a tad noisier than in the video:D
Strange as it may seem, I'm actually glad Acid mentioned toning down the map to preserve the engine.
I've noticed a lot of Biturbo's leaving MSL with much higher figures than mine after Stage 1 mapping.
Interesting they did the map before the resonator delete? I'd have expected the resonator delete first followed by the map so as to ensure the map was optimum for the config whereas removing the resonator could make a difference to fuelling parameters.
AMGeed
AMGeed
Poole, Dorset
S204 C180K
It was a timing issue Alistair. The exhaust guy was in late and Acid was ready to go when I arrived so the mapping was done first.
I agree in normal circumstances the exhaust work would be done first, then the mapping.
Jimbo1959
Ayrshire
VW Scirocco. The Quattro, E350 CDi Blue Efficiency Sport Coupe, now both gone
Guess who started the car this morning to move it for a wash and forgot to film a cold start?:(
This will have to do. A normal start without the turbos being bypassed and an idea of the volume when "on it":D
Love the casual wipe of the face with your hand to preserve anonymity.
AMGeed
AMGeed
Poole, Dorset
S204 C180K
That obvious huh?:D
I'll wear a mask when I do do a proper cold start video;)
AMGeed
AMGeed
Poole, Dorset
S204 C180K
I've just worked out I have over 1000nm of torque:shock:
1051 to be precise. Rear tyres aren't going to last long.
@ SmartAmg........... nice plate, but I don't bother with private plates.
SmartAmg
2011 E class coupe 350 CDI
Fair enough. :D
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
yeh, but Roger, that one has yer age on it too :geek::rolleyes::shock::D:D:D:cool:
