Removal of air filter housing on ML-420CDI
Mark A
Aberdeen
58 ML-320CDI.
Does anyone know how to remove the air filter housing on an ML-420CDI ? I had the filters out and removed the 2 bolts at front, but can't see what holds it at the back. I'm wanting to get to the hall sensor, which I believe is under this.
Also, anyone have an idea how I get the audio 20 out. I presume it's a case of pull the facia from around the ashtray and then I can get access to the retaining screws.
2008 W164 ML 420
Thanks in advance.
M
Mark A
Aberdeen
58 ML-320CDI.
  • #2
Anyone ?? Especially the air filter housing bit.
Roxie
Lincolnshire
C Class 350CDI 2012
2 more screws at the rear of the filter housings. They have long stems on them and don't at first look like they do anything.
M
Mark A
Aberdeen
58 ML-320CDI.
Excellent stuff, many thanks. I will have a look at the weekend.
Mark
Steve@Avantgarde
Bristol/Somerset
You will also need to recode the engine control modules adaptations to tell it it has new aor filters or it will bring on the engine management light, eventually.
M
Mark A
Aberdeen
58 ML-320CDI.
Recode the engine control modules after changing air filters ??? I take it that it's all done on STAR and I can't reset the error code using my Autel code reader. They obviously don't want home mechanics doing anything these days.
Why make things so complicated that you can't even change a filter.
