repairing broken W202 Key fob.
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
hi all, I'm posting this incase any of you have a similar problem, sure saved me some bucks and only took an hour or so to fix.
This how-to is mirrored here > http://www.niallbrady.com/mycar/c220/fixkey.html
Problem:-
* key won't open the car
* key LED won't light even with known good batteries
* chance that you may have dropped the key recently
Solution:-
In my case, the solution to the problem became evident when I took the key apart (it should prise apart quite easily, if not use gentle force), as a piece of it fell to the floor when I got the two halves open. The piece that fell on the floor was an electronic switch which had become loose from its 4 soldered leg joints.
So what do you need to accomplish this ?
* steady hand
* bright light
* a magnifying glass to see the solder joints etc..
* a soldering iron
* some solder wire
(see below)
Here is my broken key in it's disassembled state.
You can see the switch is not attached to the circuit board, and thus, the key's infrared functions cannot work.
I examined the detached switch with a magnifying glass and could see the legs were bent so I re-arrangfed them gently to be more in line with the 4 contacts on the circuit board (be gentle, if any of the legs snap off you are going to find it VERY hard to fix as they are so small).
I then aligned the switch to it's mating points on the circuit board, at this point, I held it very tightly against the board and had my soldering iron heated up for the next stage, soldering.
Once correctly aligned I carefully got a blob of solder on the end of the soldering iron and 'touched' it briefly to each of the 4 legs in turn until they clearly had solder in place. Be careful with the soldering iron, you could end up getting solder on any of the other contact areas around the switch and that wouldnt be a good idea as there are quite a few 'lines' running around it.
Here's what they looked like after the soldering process
Finally I had to reassemble the key at this point you can put the two batteries back in and you should see the familiar LED light up after a few seconds of pressing *SUCCESS*
Please note:- when you have the key all back together again, you may notice that it doesnt 'flick out' as it used to, this is simple to fix, open the key again in two halves and 'wind' the key around its centre point ONE FULL TURN in the direction of force, then place the two halves back together again.
One last note, after doing this job you'll have to RESYNC the key to your car, to do so, do as follows,
press the button on the key while pointing it at the rear view mirror then insert the key in the ignition and turn it so that all the dash board lights light up, wait a few seconds then take it out of the ignition, press again and the GREEN or RED mirror led should light. If they both flash together at the same time then try again. If they continue to flash together then replace the batteries and try again, if they flash alternatly (red/green/red/green) then you may have some other problem like the car battery).
cheers
anyweb
What a genius you are with the brilliant photos and write up.
it is possible to put an elastic band around the whole thing to hold the switch in place while you tack the first leg of the switch to the PCB.
Tactile switches are available from all TV service centers if the legs are broken on the existing switch, they come in 3 types.
Congratulations Niall .:-D :-D :-D
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
thanks malcolm, it sure was a relief when the key worked after the soldering job !
cheers
anyweb
cheers
anyweb
2000kr of relief, the pics are a joy
Doyle
Viewpark, Glasgow
i paid £120 for a new key a wee while back where was this guide then?!!!! lol
nice guide mate very helpful and ill give it a go on my other broken key.
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
did it work on your broken key ?
cheers
anyweb
lovedove13
New Registration
Key fob repair..WORKED!
THANK YOU! One of my key fob cases opened easily and by following your instructions the repair is done and it works! :grin:The problem is I can't get the other fob case opened. I'm destroying the case just trying to pry it open. :confused: Is there a trick? If I can't get it open do you know where I can get an inexpensive replacement? I can't find one on Ebay. Thank you!
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
the previous owner may have glued it shut,
just use force around the visible edges and it will come apart eventually,
forget about ebay for replacements,
cheers
anyweb
mhdgibbs
gloucester
good description and very helpful both of my keys had this problem managed to bodge one back together so can use it as spare when ive bought new one from MB dealer
If you cannot close the case again,plumbers pipe solvent will glue it, do leave it overnight to set
M30RCK
Great post, many thanks..useful to know as the keys are hard to get hold of.
W12421
Altrincham
W202 Key Fob-Fix works for W124 also
The symptoms sounded very familiar. Recently dropped my key to my W124 E280- following which it would not open the doors remotely. Changed batteries still no joy. Pressed the second spare key into action.
Looked at this post and the pictures looked very familiar- dug out my duff key and prised it apart- took a bit of effort, looked to be some glue in far corner.
Lo and behold two of the legs from the switch are detached!
Just in process of soldering together will let you know if successful.
Great post and just what makes this website so good. :D:D:D
Many Thanks
Martin
W12421
Altrincham
They may be available at a price? 20 minutes and a bit of solder and I'll treat myself to a pint of Guinness for a job well done!
Ta Niall
If you're ever in Belmullet I'll buy you a pint of Guinness. :D:D:D
paradisej
New Registration
Electronic Key Repair
Hi, Anyweb,
A million thanks to you for this posting. I owe you much. I followed your instructions, and it worked, and saved me NZD 500.00 from ordering a new set of key for my 1995 C220. It's generous bloggers like you that makes it all worthwhile.
Kind regards,
paradisej
Fakhar
New Registration
How do i actually open the remote?????
Hi, could someone out there guide me to open the remote before i do all the bits shown on the pictures.....................sorry if i am being daft..............Cheers
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
  • #19
use a knife (pen knife would be suitable) or flat blade screwdriver to prise the two havles apart
if they don't come apart easily they may have been superglued by a previous owner, in that case, use force
cheers
anyweb
