Philfi
- Feb 10, 2020
- Mercedes Sl450 R107 1980
Hi I own a R107 SL450 from 1980
I want to replace the Lambda sensor but could not find exact match of O2 sensor.
Original part nbr is A002 542 1218 or Bosch 0258001040.
I could not find identical match but purchased new sensor that was supposed to be compatible (Bosch 0258001051)
I now have a question re the wiring. Original wiring has pos and neg in one wire and ends in connector with +/-.
The new sensor only has one single wire. Assume ground is on the sensor itself connecting to the exhaust pipe.
How do I now convert the new in to the old plug. How can I connect the new sensor using the same original connector.
Thanks for support
Thanks for support
