Rev counter not not working
Has it ever worked, does it have the original radio
are these fed from the alternator or the crank sensor?
mercmancdi
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
Hi Malcolm only got car so don't know how long it has not worked , but its not org radio .
whitenemesis
CLS55 AMG '05
I'm intrigued Malcolm :confused: :confused: what could be the connection with lack of tacho & an original radio?
Speed signal?
(sorry, my name's not Malcolm..)
The green/yellow wire that goes to pin 1 on the radio is the signal that increases the volume as the car goes faster, the wrong radio can short out this signal.
Best to unplug the radio making sure that you have the code if needed and see if the rev counter works, if it does then clip the wire on pin 1, if it makes no difference the fault is elsewhere
The green/yellow wire that goes to pin 1 on the radio is the signal that increases the volume as the car goes faster, the wrong radio can short out this signal. .....
Easy when you know :lol::lol:
Naraic
2005 CL500.
Yep, everyday can be a learning experience.
mercmancdi
mercmancdi
Very detailed answer Malcolm , if that turns out to be the problem I would never have solved it ,, will try your suggestion. Thank you
It may not be that, in which case we can go further
Crank sensor always
i know of many diesels that take the rev counter feed from the alternator. fords particularly. often if the alternator stops charging the rev couter stops working. it may be different on the newer common rail engines, hence why i asked the question
