Reverse Gear Selection Problems
kellyt
Hi, I have a 2001 Vito 110cdi van and I am having trouble in selecting reverse gear, I have tried adjusting the cables but that didn't work, I guess it must be something else any ideas anyone?
Forward gears are fine.
Thanks.
Irish CClass
Navan, 30 miles north of Dublin
ML270 CDI Auto 64K miles June 2002
kellyt,
Assuming it's manual, my general experience is that the clutch spring is weak. Try it with the engine off and that'll tell you; if you can select reverse with the engine off, then the clutch is suspect, if you can't, then it may be the 'box.
Mike
roofless
w124 e220 estate
it could be worn linkage at the gearbox ect
If its that 6 speed manual box,, then there are adjustments on this
K
kellyt
The gearbox is a five speed manual, I have tried selecting reverse with the engine off but I am still getting trouble, (sometimes I can select reverse ok and other times a lot more difficult) although there is a lot of play in the weighted arm (the shorter type) on top of the gearbox.
Kelvin
There is an adjustment on that shaft, its been up before, but I have no access to the Vito info
K
kellyt
When you say there is adjustment on that shaft can you be a little clearer, which shaft? where is it situated? etc.
It was external to the box on where the selctor rod joins on,
If you can put up the Vito first set of VIN numbers I will try and do a search
K
kellyt
Ok Malcolm many thanks, the VIN is: VSA63809423364874
