Revs Rocking
*BigMac*
Wigan lancs Drives: Mercedes-Benz W202T 250TD
Another problem has arrived with my 1999 C250TD W202T
When driving and staying at a steady speed – be it 30mph 50mph or 70mph, doesn’t matter what speed I’m sat it, I get a dipping in revs then it goes back up again – this is constant, thus giving a backward and forwards rocking motion that only stops if I accelerate or decelerate and then comes back once sat at a constant speed its back.
Any ideas what might be causing this
*BigMac*
*BigMac*
Do you mean that it occurs only when the cruise control is engaged?
No fella, it’s when you sit at any steady speed - say your off to Tesco and following the flow of traffic and sat at a steady 30 then the revs drop and rise, or sat on the motorway at a steady speed, again the revs drop and rise, I’ve not tried it with the cruise on, to see if it still does it.
The revs drop and rise no matter what speed you sit at, as long as you’re just driving along normal, and not braking, accelerating or lifting off
Question
If the gearbox oil was low or contaminated that wouldn’t do it would it????, going to do a oil change on the box soon as I can’t see it ever been done on the service history, and the cars done 74000 miles now so must be about due it anyway
cheers Steve
