Roof not closing... :-(
Paul Sander
Surrey
2003 SL600
Hi guys,
Have a new issue today...dropped the roof as per normal and it went down but didn't say Roof Down to complete its cycle. When I went to close the roof it gets to where everything is closed and just the windows need to go up that little bit but thats where it stays...you can hear the mechanism still going but it just stays saying 'In Operation' with the roof symbol displayed.
I've looked at all the gaps around the boot and they all look fine...
But this means all the windows are slightly open (stay the same position when manually trying them)
It also means I cannot get into the boot...!
HELP...!!
sl500amgsport
Essex
SL500 2014
Hi guys,
HELP...!!
Try fully opening the roof with engine running.
Fully drop the windows and lift them up again.
Now try closing roof and see if window drop issue is resolved.
I am afraid that is all I can suggest from my experience with the R231 model.
Mercedes SL500 R231
Paul Sander
Paul Sander
Surrey
2003 SL600
Hi, Tried that...no luck...will take to may local MB garage...I imagine its a microswitch...MB like using tiny ones that always seem to play up...
Will the roof fully operate with the doors open
ajlsl600
france
On my vdoz the driver passenger side rear windows would sometimes not fully close turned out to be switch under door post locks. Open door hold switch in windows fully close. Micro switches seem of doubtful quality often misbehaving, also yr batt in good order.. R230 gives many headaches from low batt..
00slk
Cambridgeshire UK
Broken wire in where the roof folds?
Had the exact problem on our 500 as you have. It took my Mechanic quite a while to trace this fault. It was repaired but had a big bill :shock:
Yes right down to not being able to get the boot lid open. :rolleyes:
Paul Sander
Paul Sander
Surrey
2003 SL600
Hi guys, sorry to confuse....I don't have a window problem...its the roof not closing...
So normal roof closure operation is that when you first operate the roof switch it 1) drops all the windows a smidge; 2) boot lid comes open; 3) roof comes out and over; 4) boot lid comes down; 5) your hear everything lock down; 6) finally the windows go up that smidge and system says 'Roof closed' .....job done.
But when I do it in my car, everything is the same as above until 6) where the windows go up and the systems says Roof closed.
It just stays at 'In operation' and you can hear the mechanism whirring away...so the windows are still down a smidge and it won't let me get in the boot. I have to just have to leave it in that state...
Hope that is clearer... :)
Paul Sander
Paul Sander
Surrey
2003 SL600
Sorry to add...the roof opens ok..
00slk
Cambridgeshire UK
Yep same with ours ;)
It would open okay, close okay but the motor kept werring and the windows stayed open that smidgen.
I think if I remember rightly the break was in the n/s rear C pillar
Paul Sander
Paul Sander
Surrey
2003 SL600
Damn... so when you say big bill...in the region of??? ...(I'm sitting down) lol
00slk
Cambridgeshire UK
Found the bill which says, 'pull car apart to find broke wiring
£540.96p
00slk
Cambridgeshire UK
FOR SALE
MERCEDES SL600
PERFECT CONDITION
IDEAL FOR SUMMER DAYS ONLY
To be fair my indy was given a blank canvas to start off with, so maybe it will be cheaper for you knowing that a good place to start would be the roof where the folds.
Bet you'd have no difficulty selling your SL600 ;)
Paul Sander
Paul Sander
Surrey
2003 SL600
Hopefully it will cheaper...if they actually listen... :)
And won't be selling it...its the ultimate sleeper car...and apparently there's only 300 in UK (100 of those are SORN'd)....
ajlsl600
france
Good luck. Had a beauty v doz bi-turbo myself. Loved it. Knew it would bite me at some point at 62 had some lovely runs but needed lfe to get less complex not more. So... Wot I do? Buy ml250 complete with another suitcase of Dtf!! Hope I don't regret that to much??
Go with checking continuity of wires as suggested. If yr sparky pointed in right area should know in about an hr.
By the way tidy sl600 r230 sell themselfs. Sold mine to first guy who came, bit my hand off and pretty much what I paid for it six yr earlier.
Paul Sander
Paul Sander
Surrey
2003 SL600
  • #17
Cheers for that and good luck with the suitcase..! lol
Adamki83
Mercedes E-class, 2005, E270CDI (2.7) + 1992 Mercedes 500SL (R129)
Hi guys,
HELP...!!
Just out of interest had the battery been disconnected at any point?
This may help:
  • Vario Roof Diagnostic Aid.pdf
Paul Sander
Paul Sander
Surrey
2003 SL600
  • #20
Hi, Finally got round to taking the old girl in to get the roof sorted...told them about your issue and to check broken wire...and hey presto...same thing h=which they went straight to...£120.00 bill...so many thanks for that. :)
www.ckinsurance.co.uk
