Running problems on an '85 380se
troylatif
Hi guys, I'm new to this forum. I'm having some running trouble with my 380se. It started about a few days ago when in the mornings i started to notice that the engine would stall a little bit, but it could be started again and would run as things warmed up a bit. Today it has reached the point where the car will not continue running unless it is given some throttle.
I initially suspected the fuel pump, but I can't be sure because I feel like the car shouldn't run at all if the fuel pump isn't pushing gas even to keep the car idling. The car will absolutely not idle. Could it be the fuel pump relay?
Well, at any rate, your advice is much appreciated.
-Troy
