- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
Hawk read what you have said and argue with yourself, not with me thank you
Try reading it and quoting what I actually said next time.
First you quite wrongly state I have never dealt with rust -even though you had no means of knowing whether that was true or not. And then you completely misquote what I said about the rust on the OP's car.
I shall be very happy if you manage to refrain from doing this in future.
As before read what you have said
That's a bit worrying as it's a mainstream model, built in Germany and well after Mercedes claim the rust problem is sorted by using galvanised sheet.I am now in an incedible position where our 2006 CLS has more rust on it than the 1984 panels hanging on a '79 Granada!!
I don't see how it can be the steel used as most car body steel is recycled, but as a part of the recycling process impurities are removed as slag.
From what I see it's due to poor design leaving vulnerable edges exposed and then poor primer and top-coat application. The primer doesn't really seem to grip the metal very well in certain areas.
this is the poor pre paint prep observed in a previous post. I suspect he steel isn't being properly cleaned prior to paint application.
I understand what you are saying, but that could just be because the rust has already migrated through the steel before becoming visible on the exterior.When I removed some rust with stripper so as not to disturb the metal there were microscopic holes in the metal, brown in colour
don't forget there would be no wax rustproofing applied to the rear of the panel and the paint coat there is rubbish.
The very nature of steel manufacture excludes rust from the finished product.
My suspicion is that the primer fails to make a proper bond to the steel and draws moisture under it for a long time before there is anything visible by way of a bubble.
The moisture allows rust to gradually eat away at the steel under the primer, thus the pock marks you are seeing and also along with the spider webbing often seen.
For sure there is something wrong with the primer and the bonding, as we all know most cars get a stone chip and nothing much happens, nothing happens on my 12 year old V70R there are a few chips, but nowhere near as bad as the MB and they have never been touched up, but at the same time still tiny chips, unlike the huge scabs that appear on MB's from nowhere. My V70R wheel arches are as good as when it left the factory
Trade-in your sl for new model R231 in 2012 aluminium body i believe not rust i hope
Thanks Matt..I hope that it last OK after all that.. If only firms new how to relate to customers
