s 280 140 model
Status
Not open for further replies.
neilairman
royal berks
does any one know if the rear subframe rubber mounts, infront of the rear wheels are easy to replace ?.
there is a plate with a bolt going thru it and the subframe is rubbing on it.
when you compare it to the other side there is a reasonable amount of rubber showing and the subframe is not touching the plate with the bolt. :?
Status
www.W140.co.uk&www.r129.co
