S Class w140 heater booster fan stopped working
star
Reading
Smart + others :)
Duh, got any idea on size or which ones, I didn't measure them before i let the car go.
I do have a spare motor here,,and I will try and measure them up
380560
Isle of Skye Highlands
S Class, W140 4.2 Limo, Nissan 300ZX twin turbo, Porsche 911.
  • #24
..........could i ask you where the regulator is situated, is it on the blower. I know this sounds stupid, but I have refitted the cover etc above the blower yesterday. Thanks
In the link in post 2 it is the 253-260 part it is fixed in by the side of the motor
Star,, the brushes are 8.5mm x 10mm for the fan in the picture
star
Reading
Smart + others :)
Thanks M, but thats the wrong fan unit for a 140 chassis. I wonder if they use the same brushes?
380560
  • #28
is the resistor the same as a regulator, yes great, if not where is the resistor and if that has blown, would that stop the booster blower from increasing/ decreasing in power? Would you suggest I replace both (if indeed they are dfferent!?)
Yes its a 124 If the OP here does take his motor out the will be a Bosch number on it,, if we had that then it makes it much easier to do a search. The MB cat number is not the same
380560
  • #30
This ref my S Class W140.........
There is no resistor as these were dropped some years back and the solid state regulator has been used since.
They are often on Ebay cheap
380560
  • #32
I have just had the daily post up here on Skye and the postie handed me a parcel which contained my new regulator. After about 15mins it was fitted. I reconnected the battery and with baited breath I turned on the ignition.........
I was greeted with a boost of air which nearly pushed me through the back window!!!!!!!!!!SUCCESS. Many thanks to EVERYONE for your help and knowledge. The total cost was just £59.99 + £2.95 p&p for a NEW regulator!
Thanks again guys I owe you a drink.
Your nice post above is all we need,,It makes life on here all worth while :D:D
fazzah
Cheshire UK
W140 300SE 1993 + W140 S320 1996
Regulator/resistor
I had the same problem with my W140 1993
It turned out to be the resistor/regulator which is mounted above the blower motor on the left under the bonnet
Pleased that you have warm feet now
