S320 1997 BAS/SRS Light ON
RCA918
The '97 S320 BAS/SRS indicator light in on. What does this indicate & how to resolve?
opps-man
Liverpool
BAS is Brake Assist & SRS is Airbag. both of them need to be reset by plugging the car in to a computer. look in your lacal yellow pages for an independant Mercedes Garage to find and rectify the fault and also reset the warning lights.
Cheers
Don.
R
RCA918
The BAS & SRS seem to be on the same 1 warning indicator line?
Will turning the battery off from the car or perhaps checking the fuse resolve this ?
With BAS on, is it indicating its malfuctioning part or just a computer error as you suggest?
You could try disconnecting battery for 5 min's, if not fixed, do as opps mans say's you must get the code read and cleared.
malcolm
piestore
manchester
bas /srs
If The srs light is on it will stay on untill the fault is cleared by a star machine, BAS light will go out when the fault is no longer present after ignition reset, are you sure that your fault display isn't BAS/ ESP this would be more comon
R
RCA918
Apologies, you are right its BAS/ESP under 1 light. BAS is Brake Assist * what is ESP? It comes on everytime conering. When the engine restart, it will reset but it will appear again when driving & conering.
Is it right that if I disconnect battery it will be a permanent reset?
Also how do i read the error code & reset it?
R
RCA918
BAS/ASR indicator light on
Apologies, its BAS/ASR fault not ESP. Can any 1 help to how to read the code or reset pls.
Brake light switch
This makes it better, should be just the brake light switch that sits over the brake pedal, and held on with a 17mm nut, 2 or 3 wires.
Cost £10 max and easy to do.
Malcolm
R
RCA918
Television,
Thanks.
Where is the Brake Light switch? A diagram or pic will help?
