S500 W222 noisy start up
S500 Pete
Essex
S500 (W222) 2014. Turbo 4.7 V8 with loads of toys. Superfast luxury.
Hi all,
Loving my S class but it is very noisy for about 10 seconds when started up from cold. A sort of cam follower or chain rattling noise. Cant really hear it from inside but from outside it is like an old diesel.
4.7 biturbo engine.
Anyone got any ideas or is it normal? I thought it might be something that needs oil pressure to stop it.
ajlsl600
france
If you crank stop crank 4, 5 times before you let motor catch does the rattle, noise dissappear?
If so my money is on camfollowers draining down.
star
Reading
Smart + others :)
Just doing a 221 s500, 278 engine chains and sprockets. One cam sprocket has a delivery date of March!!!!
John Laidlaw
Wirral
Land Rover Discovery 4
Cat bypass to heat up the turbos?
S500 Pete
S500 Pete
Essex
Cam followers draining was one of my thoughts. I will try your suggestion.
ajlsl600
france
If tis that wouldnt worry too much .you can also get a pre lube kit. Puts oil light out BEFORE start .mine was 350 usd. Prob cheaper than tear down and followers replacement .
merc85
HARWICH
E320 cdi
Did the Op ever get to the bottom of this?
