Saving my Back
silb
C Class 2017 1.8ltr
Hi guys,
New to the forums here, but was hoping to get a bit of expertise. Love working on the car, but I've been suffering from a bad back in recent years (showing my age!) Was thinking in investing in a lower back support like this, but was wondering if that would be better for heavy lifting, rather than bending. If you have a later era A-Class, you'll know how long you have to spend hunched over the open engine bay!
All the best,
Chris
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Hi and welcome,
Bending over an engine bay puts pressure and strain on more than just your waist as you probably already know. Neck, shoulders and back all suffer along with hips and thighs.
Not sure about the support thing but more lifting I suspect.
Work with a few more breaks and have a look at Pilates, not just for ladies, invented by a bloke and has sorted out my back, middle and keeps it well.
EmilysDad
Bury Lancs
ML350
Working on an engine also hurts my knees ... I tend to lean on the front bumper with my knees when reaching towards the back
Hello and welcome
davemercedes
Glos
Hello silb and welcome. Never tried this kind of support - it looks like the "corsets" that weight lifters etc wear. Unfortunately, I'm too far gone with osteoarthritis and any work on the car is generally too painful now. If it works for you, then good luck!
star
Reading
Smart + others :)
Yoga sorted mine. :)
Chrishazle
Nr Ashford, Kent
That looks a bit like the spine support corset the NHS gave me about 45 years ago, except my thing had 2 aluminium bars one each side of my spine. I could only bend forward or back about 10 degrees while wearing it, had to "bend ze knees" to pick anything up from the ground. Didn't do much good either!
davemercedes
Glos
I had one knee replaced and it's never been right for me. After LOTS of scans, injections etc I ended up with a specialist at our Pain Clinic who prescribed enough daily drugs for me to set up a stall in the market. That was five+ years ago and I now take so many pills that I rattle! My (superb) surgeon agreed that I should not have my second knee done because it would be as complicated as the first, all over again.
Frontstep
T210 320cdi
They do work and well but use only while working.
I have had some "issues" and without the use of one when needed I would have been prevented from working.
They do not though replace a sensible weight, good diet and exercise.
If you sport a big stomach then be realistic it's doing you harm.
That particular model seems expensive but I haven't had one in my hands.
Chrishazle
Nr Ashford, Kent
Thanks Frontstep, that's given me food for thought. I have a partially collapsed L5S1 disc, probably also split, and chose to live with it rather than go under the knife - which is what the Horder clinic (specialist orthopaedic clinic) wanted to do. Unfortunately the osteopath who was doing a load of good using deep tissue massage, flexion/extension and US osteopathic techniques had to stop practising (long story) and I've never been able to find another osteopath using the same techniques.
Frontstep
T210 320cdi
If you have a diagnosis then try one by all means they do help in certain circumstances and (only from my experience) life changing.
Bit like a splint on a break it stops you going where it hurts, don't live in it though.
00slk
Cambridgeshire UK
2002 SL55 AMG, 2005 E320 CDi,
I suffer badly from Osteoarthritis and have done for many years, I have also had over 9 operations for treatment and replacement knee, toe fusing etc, the worse was when I crushed and broke a disc in the lower back, due to incorrect lifting and working on car techniques and lack of exercise over my years. The doctors never understood my issues as I just grinned and bared it and their advise was to try all these supports and braces etc which never worked for me. I find that if I stop moving, even to sit and eat or be on the lap top for a little time I struggle to start moving again (hence all the cars I own just so I can do things and work on them to keep me from seizing up) I have been going to the Physio who has been giving me a few different exercises to do which I have found excellent and eases the pain I get when trying to sleep at night from my hips. I'm also on 21 pills a day for arthritis and other aliments but I am afraid the best help you can get for yourself is exercise and I hate doing it, Why, because it hurts a little and is boring but in the end it also reliefs a majority of pain.
Just my two pence worth :)
Think I will go onto the shed and pull out a car door and strip it :D
umblecumbuz
Wales and Gozo
The advice I was given by my osteopath was very simple.
Wear one if needed while doing jobs that would otherwise give extra strain, but do not wear it constantly.
The reason is that the muscles will deteriorate fast if they have no work to do, and you will eventually suffer more as a result.
Makes a lot of sense.
Tel: 020 8863 9233
