Service cost - C220
Ian Dagley
C220d estate Premium, 2017.
My C220 , 17 plate is due it's AO service.
Merc are quoting £626 . That seems pretty steep to me .
I've been quoted by a indy £244 + vat.
Which I've just found out up on the approved mercedes garage app on here. So that makes me more comfortable.
I'm in two minds which way to go.
Do I keep Merc history, is it really worth it.
I'm thinking more in a couple of years when I trade in.
Thanks in advance.
Hello and welcome
As long as it is serviced to the required standard then the residual value will be unaffected.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Do you know exactly what needs doing? Put the car details in here and it will tell you what needs doing https://www.mymercedesservice.co.uk/#/your-vehicle
You can then easily compare prices, any good MB specialist will be able yo keep your Digital Service Record up to date so when you do change it is all there for the next owner.
Which indy are quoted you?
You will loose Mobilio breakdown cover for the car by going outside MB for servicing which needs to be factored in . Have you looked into an MB service plan and factored in the costs of that for 2 years or up until you intend to trade the car in .
But as above your trade in value won’t be affected either way
I
Ian Dagley
Yes , that was where I got the quote for £626.
The indy is a garage in Derby called German automotive. They can update the digital service record.
Also ring around other MB dealers for cheaper quotes ?
I
Ian Dagley
Yes , I did that. They knocked a bit off . Not enough to tempt me though.
£330 difference in service prices will buy a fairly comprehensive breakdown package
It will , and that’s what I would do/have done , but the OP hadn’t mentioned it so I thought he should be fully informed of his choices :D
JBell
Torquey
Exactly what I would do and RAC have a half price sale on ATM
I
Ian Dagley
I've already got breakdown cover with the AA , good benefits with them !!
I
Ian Dagley
I did look at the service plan . And to be honest, it wasn't too bad . £38 a month . But I'd rather pay it one go.
I
Ian Dagley
I think so m8. Keep the little guys going !!
Funkyboy
Liverpool
E250 w212 14 plate
Check out the monthly service plan much cheaper than paying for each service. Doesn't make sense must be because they like the monthly payments. It covers all the service items that are required
You have to do your sums , if you take a 3 year plan out on schedule A B A , at the price the op quoted of £38pm , you have paid nearly £1500 for 2 oil changes and a B service :eek: .
If you timed it at B A B and had a gearbox oil change you are closer to getting your moneys worth
I’ve also seen threads here where owners have been told by Mercedes that work is required as part of the service, when the owner says “great it’s on a service plan” the work is suddenly no longer required...and/or not covered by the plan. :mad::shock:
Devils in the detail :D
