six cyclinder diesel
Smokeyone
Hello
I am trying to find out about a particular MB diesel engine - the six cyclinder 3 litre turbo engine code 603.960 around 1988/93 ish probably the E class.
It's for an engine swap into a range rover and as I have already found out - no electronics involved on this particular engine, mechanical fuel pump etc.
Wonderful, no ecu to go wrong...
Any opinions on the engine and any ideas where I might find the specs please - size/diamentions/weight/hp/torque.
Thanks for any advice
Number_Cruncher
1995 W124 E300D TE
There is an ECU which controls idle speed and EGR.
Smokeyone
So I was given duff info because I am looking for one without an ecu.....
Number_Cruncher
1995 W124 E300D TE
It's not as bad as later ECUs - it isn't coded to the car or anything difficult like that. As long as you get all the wiring and the ECU, it should work OK.
Smokeyone
Thanks very much for the info........any suggestions where I might find the specs for the engine please...........
