sl 129 instrument cluster
e55amggary
Bristol
C220cdi sport edition Auto / A6 2.7tdi Quattro s line Avant
Is it possible to remove the cluster in my 129 without taking the steering wheel off??There are no adjustments on steering wheel for movement.I know how to get it out,but is there room?
stats007
Hampshire
Looking
There is. Use the removal tools and wiggle slowly from side to side or drop the trim below it and push from behind.
A stats,,there is just enough room
stats007
Hampshire
Looking
My R129 had an electric steering column - can't remember if they all had them?
On the early 129's an electric adjustable was standard on the 500 and 600 but extra on the 280,320, this was up to 08 98 then became standard to the end of the run 2001-2
