Sl 500 Problems
forktruck
Just had SL500 2002 year 50,000 miles serviced.
Needs 2 rear shocks £800 each
Active Body Control pump £850
Both front suspension arms worn.
Any body else sufferd similar problems.?
Hello and welcome, yes to struts gone at 20k miles, Who did the test
F
forktruck
Local Merc specialist, any assistance from MB
stats007
Hampshire
Looking
I thought the ABC pumps were pretty common failure issues?
F
forktruck
Understand pumps a regular problem.
Rear shocks described as one leaking and one damp.
No help from MB then:confused:
stats007
Hampshire
Looking
All the W215s I looked at had had them replaced that's all.
I have to agree with BlackC55 the pumps are not a problem, first time that I have heard of one if it has gone
What are the symptoms with the car
The rear struts cost £965
The MOT ruling on this is that they can be damp (advisory) but not drip
F
forktruck
Hi Television.
The car has no problems just that the ABC warning come up
Hi Television.
Is it white or red the warning, have you checked the level of the fluid.
Does it come on from the time that you start the car, or after it has been running
F
forktruck
Warning comes up in the screen just black script ABC visit workshop.
Level was checked and topped up, warning comes on from time to time, always
when driving.
when driving.
Just out of interest will the car height change on the button, when the visit workshop light is on.
I will do some checking this evening
F
forktruck
Thanks, not checked height, but will do next time
BlackC55
South coast
C43
It is either the pressure sensors that are the problem or the valve that I previously mentioned.
What were the fault codes?
A small leak is "generally" ok to live with and not un-common.
There are not many cars with ABC that are a few years old and have NO ABC fluid leak at all.
The fluid is called Pentosin BTW. (green stinky stuff)
F
forktruck
Do not know the fault codes only the message centre warning, Merc-Care in Leeds advised that the pump was faulty, so much so they have pumps on back order
